Known Issues in Release 10.7.2
Table 1. Known issues in 10.7.2
Issue ID Description
HOS-17683 Some WPA3 clients cannot associate to the AP4000 properly when band steering is enabled.
Workaround: Disable band steering.
HOS-18313 AP5010, AP5050D, and AP5050U devices will not boot when some non-Extreme micro-USB cables are connected.
Note:
For all Extreme Networks access points, use the Extreme Networks certified ACC-WIFI-MICRO-USB console cable. Other MICRO-USB console cables have not been certified by Extreme Networks.
Workaround: Use an Extreme Networks certified console cable, or plug in the cable after the AP boots.
